Haven't had a chance to look at the cruise anymore lately, but I've been working on some other bits and still using it daily :)
Short video from an afternoon of offroading a couple of weeks ago - https://youtu.be/J9zTN_6wNw4
In low range you barely need any throttle - if any at all. It just pulls at idle so nicely. The others were impressed at how well it did - and how smooth it looked following them in the 90, bouncing around. AC, comfortable seat, auto - what more do you want.
Otherwise... everything has been more or less fine. Did have an issue with it cutting out after a few hours of running during the summer - turned out to be a worn o-ring on the high pressure pump's regulator. Then had an injector fail. Or possibly the other way around I can't remember. Either way - both now sorted.
Diesel heater's coolant pump started to struggle pumping before giving up completely, so swapped another pump in and I'm back to being able to preheat in the mornings :)
The P38 is now on 171k, putting the engine on err 177k now. 9k done since the conversion 15 ish months ago and loving it.
                            Southampton with a Nanocom for Thor/GEMS P38s
1996 4.6 HSE, then became a 4.0, now cubed.
1997-8 4.6 HSE Motronic/Wabco prototype vehicle. Now M57 powered. Still auto.
