Next week will be judgement day, whether she passes or fails..
Known faults are...
ABS TC light are intermittent, i believe it is because of a lack of pressure in the ABS system, i will try and leave the pump to run till' it cuts on the day..
Gearbox fault is another the Sport and manual modes don't work and it won't change below 2500rpm so i need to look into that.
Cold start idle is all over the shop, ok when hot..
Exhaust is rough..
etc etc
we'll see!!
H
Interesting times ahead :)
Mine passed last friday with 3 advisories.
Monitor and repair if necessary (advisories):
Nearside Front transmission cooler pipes slightly leaking
Central Rear exhaust box slightly leaking
Offside Rear Brake pipe corroded, covered in grease or other material (1.1.11 (c))
Well chuffed
