Okay, I got them out, but there must be a better way. Thin walled sockets, or other special tools? The transfer case end of the front prop shaft was especially difficult.
Drive shaft or prop shaft?
If you mean propshafts, there's a special 3/8in socket that fits
Better than 1/2in as it fits better.
https://www.manomano.co.uk/catalogue/p/9-16-land-rover-prop-shaft-nut-bolt-socket-tool-3-8-square-drive-17701704?model_id=17699706
It's also easier with suspension on lower setting. Leaves less crawl room though.
If you are talking about the prop shaft bolts, as Tanis8472 mentioned, there is a special tool:
https://www.island-4x4.co.uk/propshaft-socket-drive-land-rover-laser-6151-da1119-ba3138-p-37830.html
Yes, it is thin walled, so it fits over the nuts.
It is still a pain though. The bottom ones and those within reach are easy enough to remove but you can't get to the bolts higher up without rotating the propshaft/wheel and you can't do that with the handbrake on. So you need to jack up one wheel, support it on an axle stand, take the handbrake off and rotate the wheel. Then put the handbrake back on before you crawl underneath.
Thanks for the replies. Yes, prop shafts. I'm Canadian, where the term driveshaft is used, but also I've lived in the British car world for decades so I should have known to write prop shaft.
I'll be ordering the tool!
3/8 drive socket and a universal flex joint will do it
It's a pain, but with the correct tool even I managed it - although it was coming off for the second time. Marty's impact had loosened it up about 300 miles before when we changed the UJs.
Follow the routine above for safety and it'll be fine.
