Hi guys, I wonder whether someone could upload a picture showing where the VIN number on the front of the chassis is ?
I am getting grief from the tossers at my local NCT [MOT equivalent but worse] test station. They are not satisfied with the ones that you can see normally, the numpties "want to see" the chassis one. Unfortunately, my motor has been painted with heavy "underseal" so I can't find anything !!
outside of the right front chassis leg.
Here
Thanks, Gilbert, I will have a root about and try to clean it off.
Wow, they must be picky, normally my guys just read it from one of the ones that's visible.
It's on a plaque under the windscreen and on the slam panel above the passengers side headlight.
David.
