Hi Guys, looks like i need to replace my temp sensor. Whats the latest on getting this part? I can't seem to find it anywhere?
Cheers
It's made of unobtainium in short you might be lucky on eBay ---£100 believe it or not or try a breaker for one ---- but the part unavailable 🙄
Or 81p from RS Components. See here https://rangerovers.pub/topic/2147-heater-core-temperature-sensor-thermistor
i'm up for a bit of diy... will have a look.
thanks
Well this seemed to work fine! I used the existing sensor bracket and drilled out the alloy pad that touches the pipe, replacing directly with the thermistor. Then 2 x 1.5mm holes through to the collector pins and poked the thermistor legs through. Heated the pins with soldering iron and touched a bit of solder on the legs to join them together.
Nanocom shows a reading now and no faults. Happy with that!
