I was looking for the OBD connector and found this taped to the lower frame of the drivers side kick panel alongside a relay. It looks as if it was factory tape so guess the earliest ones don't have obd2 and this was just lashed up pre production.
Is there a particular adapter to connect to a Nanocom?
Thanks as always.
No, that's C243 that plugs into the cruise control ECU which you obviously don't have. The yellow one next to it would plug into the cruise inverter module. Mine is the same, no cruise but the plugs and wiring are there. The OBD socket is on the passenger side, right at the front near the bulkhead and next to the centre console.
Of course. Thanks Richard. Needed to crane my neck round further!
It's quite a weird position for ODBII to be fair...
