Straight to the point really gents!
Some pillock opened their door on to my door handle with some considerable force I might add and have caved the door handle in to the door creating a nice crease..
The Door itself has a few electrical bits in it, does anyone know whether there is just one big loom plug to remove?
Thanks H
Get the multiplug out of the rubber connector and then you are ready to unbolt the door directly, with glass and all - mind the weight though.
I would leave the hinges on the body, it saves from having to repaint them.
Bear in mind you will need to align the door after ...
Ta very much,
sounds quite simple!
