Hi folks,
Can someone recommend a really good sparky that could do a small bit of work for me on my P38? I just need a couple of the connectors removed/replaced and soldering. I can travel within reason but need the job done asap.
Cheers
Craig
You don't really need a sparky, just someone that can use a soldering iron. If, as I suspect, you are talking about the connectors behind the footwell kick panels, it just needs doing carefully, one wire at a time. Snip one wire at one connector, solder a short jumper wire to it, snip the matching one from the other connector, solder the jumper wire to it and then move on to the next wire.
Yep, that's exactly what needs to be done. I am unable to do it.
Thanks
Administrator
Aw man I work in Hamilton but I'm crazy busy right now. Will you survive a couple of weeks with it the way it is?
Sure. The dash lights haven't been working for months now. I have gone right through absolutely everything with it and this is hopefully the last bit of the puzzle to sort it out. Hopefully.
