Hmm seems the old Range rovers valley gasket has shit the bed, a small puddle in work carpark was the telltale..
Coolant seems to be running off the Trans cooler lines and bell housing..
looks like a simple enough job, bloody Gas kit which profess autogas did a very neat "not" job of installing and their haphazard wiring is going to be fun...
Looks like valley to me.
Any ideas?
Cheers
use a mirror and a torch to look under things , give it a wash and then look for the leak. find it before you assume what it is.
Or a core plug behind the flywheel.....
Clean it all off and pressurise the cooling system which should show where it is coming from.
Thanks gents.
Yep i've since hosed the entire underside with TFR and brake cleaner and the leak is definitely dripping down on to the trans cooler pipes and subsequently down the side of the bell housing.
Core plugs are in good nick thankfully.
if thats the case you can check the inlet manifold and valley gasket as you work your way towards the heads 😊
