I was reading through a few threads about problems with latches going faulty and I noticed that Richard [GilbertD] mentioned that the door latches fitted to the MG F are the same as fitted to a 2001 P38.
RH https://rimmerbros.com/Item--i-FQJ102281PMA and LH https://rimmerbros.com/Item--i-FQJ102292PMA
I wonder, are these a straight swap ? But having asked the question here I see that they don't appear to be available any more. I'd be interested to find out whether they can still be bought. I will look elsewhere on the wobbly wonder web and see what comes up. I wouldn't be surprised if they are available, in LHD form, in the US.
UPDATE: I looked up the part numbers and, indeed, they are LHD car part numbers. So I think that probably answers the question - that they are NLA.
The ones for a LHD car are no good to you. The passenger side, your driver's side, only has one microswitch so won't work in a P38. The LH one, driver's side on a LHD car would work in your passenger door though. RHD diver's ones are available at around half the price of a P38 latch from https://www.ukmgparts.com/product/mgf-mgf14-exterior-bodyshell-panels/door-lock-rh-mgf-tf-rhd-fqj102262pma. This one has the 6+1 plug used on a pre-99 car so the plug would need to be changed to the 8 way plug (with only 7 wires used) to fit a later car.
Pierre, I don’t remember if you are LHD or RHD. On mine I tried the RHD assembly in the RH door of my LHD vehicle and it didn’t work.
https://rangerovers.pub/topic/2330-right-front-door-latch
I bought one and put into stock, as I know that come the time I need one, they will be akin to hens' teeth
Hi, interesting reading. I had often thought about buying a drivers' side latch, for a LHD car, to fit on the passenger side door of my car, a RHD P38. But as has been mentioned, the RHD drivers' side latch can be the problem. I looked it up yesterday and, as you guys are probably well aware, the are around £250 a piece.
I had to buy and fit a new one last year, myself. It has been in for about 12-15 months, but for some reason known only to itself it started the cill button locking trick. I stopped outside someones house, about a month ago and found that the doors were locked, and, as happens in these cases, when I pulled up the cill buttin it just popped straight back down.
I stripped the latch out and soaked it in Starrett light oil and it seems to be perfect again. What I have noticed is that it locks much quicker than before, and operates more quietly. It had been running for a couple of seconds previously, before it locked, so I had an idea that something was not quite right, but then it is a pretty new latch mechanism so I didn't pay that much attention to it ! Sort of a slow-motion lock.
Anyway, it is working fine now, so hopefully it stays that way.
