Like a cheapskate, I bought 2 single coil packs for the SE rather than the bracketed version. Only problem is, the HT/ cylinder lead numbering is identical on each (1,2,3,4), which isn't a great help!
Do I just wire them as per the published RAVE picture?
The input plugs look identical in every respect so can't see any issue there.
Thanks in advance
Mark
Remove the bracket with coils and wires attached. Place on bench and swap everything over. You have to install new coils on the bracket anyway.
On LHD truck without SAI you can pull the whole assemply out on the right hand side. Not sure if that will work with RHD.
The lay-out is as pictured, as long as you have one 3-pin input connector at each side it is just as you showed.
