I think something on the building site next door is triggering the RF unit/BECM. The Battery dies in about a day now, and it's taking a toll!
I'll have to disconnect a terminal between trips I reckon :(
Try just disconnecting the blue wire to the receiver for starters. That will reduce the operational range of the receiver and may be enough to stop it.
Thanks Mr G! I'll give that a go.
I need to see if the battery is still sound after another deep discharge :(
I thought your one had been upgraded to a new RF Receiver?
I have some RF Filters available again - so drop me a message if you want one at any point!
Marty
My RF unit is stock as far as I know. As she's a 2001, I guess it's gen2? IIRC the gen3 weren't available until after the production run had finished... not sure.
I'd be interested in a Marty RF unit! although, maybe once I've recovered from Christmas. The next priority is an EAS rebuild! She's squatting at the back, evenly. So I think it's the NRV in the valve block or something that is common to both rear lines at least. The rear bags are two years old.
