blueplasticsoulman wrote:
If you suspect compressor, undo blue pipe that goes from compressor to block.  Run the compressor using nanocom and stick your thumb over the end of the pipe.  You shouldn't be able to stop the air coming out.  If you can you either need to rebuild the liner and piston seal which is the most common or worst case compressor motor jiggered and need new compressor.  Seal kit [here](https://www.ebay.co.uk/itm/RANGE-ROVER-P38-EAS-AIR-SUSPENSION-COMPRESSOR-PISTON-LINER-SEAL-REPAIR-FIX-KIT/272849987820?
fits=Plat_Gen%3AMK+II&hash=item3f872068ec:g:qAsAAOSwEeFVGUon).  Video instructions here
To visually inspect the liner just watch video above on how to take the compressor head off.  5 minute job
to confirm if it's banjaxed.
The fact compressor is making noise, itโs possible that a rebuild of the liner and ring might not work, could be the bearings gone.
Iโve got a spare compressor if you need it miles, just drop me a line and Iโll UPS it next day..
                            Late 2000 4.6 vouge, 20" khans, running lpg. Exchange LR engine with low miles.
2.5 dse sold oct 2015
1997 green 4.6 vouge, sold Feb 2014
1997 blue 4.6 vouge, sold June 2013
1992 blue 3.9 classis, gave away 2010
1989 gold 3.5 classic, sold 2006
Etc etc missed out lots, on 14th Range Rover
Nano evo, Thor , dse, EAS kicker..
