After a bit of water......
As Phil says, ignition lock has been pulled out so it can be started with a pair of pliers.  EKA entered with the Nanocom (it comes complete with all the handbooks including the service book and the all important security card) and, after syncing the BeCM and ECU, it fired up on a squirt or two of brake cleaner as the fuel tank was completely empty.  Bunged half a gallon of petrol in it (that was all we had) and it fired up on that.  Engine sounds very nice with no nasty noises, overheating or oil leaks.  After letting the EAS compressor run for a few minutes with a door open, the EAS appears to be working perfectly and it shot straight up to the High setting.  Seemed a bit reluctant to lower but it probably just needs a bit of use, it has been standing for over 5 years after all.  Transfer case would select high and low ratios too, so nothing to worry about there either.  Central locking works from the sill locking button on the drivers door so no reason to think it won't work from a key (once you've got one!).  Even the drivers heated seat works.....
I'd say it doesn't need the BeCM and ECU changing (there's no need to swap both as the Nanocom can sync a replacement BeCM to an existing ECU), but CRNW can make a key blade to fit the existing locks.  OK you wouldn't have a remote but it is a cheap option to be able to lock, unlock and start it.  They could also supply a remote but at a greater cost.
The minimum needed is a key, a battery, a lambda sensor (idle sounded like it may have been running on 7 but the Nanocom reported an error on one lambda sensor so I suspect that was the cause), a pair of wiper blades, the rear brake pipe replacing (although probably wise to do the other side too) and a pair of rear tyres and that should be enough to get it through an MoT.  For finishing it off, it needs a good clean, a headlining kit from Martrim, a zebra strip in the HEVAC (no idea if there are any problems there as more segments don't work than do).  One of the blend motors didn't seem to want to do anything but what would you expect on a car that has been standing that long?  They may well start to work with a bit of use too.
It is a very good basis for a really nice car with a relatively minor bit of work.  We both decided if we had a nice, warm, workshop or it was mid summer, in a week we could get it almost perfect, but as neither of us has a nice, warm, workshop (and it isn't the middle of summer), it would be good to see it go to someone who does have who can return it to its former glory and get some use out of it.
- '98 Ex-Greater Manchester Police motorway patrol car, Range Rover P38 4.0, in Chawton white - the everyday car
