Well yesterday actually.
Summoned to Manchester for month over Christmas by the "official un-official kid sister" the big red beast appreciated the chance to stretch his legs and clear his sinuses over 300 odd miles at motorway speeds. I'd forgotten just how good the P38 is at the magic carpet bit when settled on a decent road.
But now we are here he has dropped down onto the bump stops so clearly a leak somewhere. Took about 3 - 4 hours to drop I think.
Is there anything obvious I could check, and perhaps sort with only my on car toolkit, 300 miles away from the big toolbox and the set of new airbags in the spares department?
If not is another 4 hours / 300 miles (mostly) on smooth motorway roads with a leak of that size likely to be OK without killing the air pump or thermal fuse. Should have been suspicious when he'd dropped after loading the night before and took about twice as long to lift as he normally takes on the odd occasion when I park in just the wrong place so he self levels down.
If worse comes to worse it might be possible to get the bags sent up and arrange fitting up here, assuming it is a bag. They are old enough that I don't mind changing on spec.
Start it up and see how long it takes to rise up to standard height and then see how long it is before the compressor shuts off. Once up to standard, switch off and pull fuse 29 (assuming a Thor, fuse 44 if GEMS). That will stop it from self levelling and is a lot easier to get at than grovelling under the passenger seat trying to find the timer relay. Then wait and see what happens. That will tell you if it is one corner dropping due to an air spring leak or something common to all corners.
Thanks for that advice.
It's well over a decade since I've had any non obvious suspension issues and I've forgotten all the tricks.
Should be able to find some time for that over the next day or four. When I'm not under orders!
Possibly the two ugliest words in the P38 lexicon:
Ball Joints.
Finally got psyched up enough to tackle these on Bolt.
Middling decent hand tools loaned by the local O'Reilly's auto parts shop.
Actually, the job was not as bad as I thought it would be.
4 hours for the first set an a bit over 2 for the second ones.
I would like to know what the proper press cup looks like for the bottom one?
Had to use a cut off wheel on the grinder to cut off the flange on the bottom of the lower to allow it to be
pressed out.
The first set only lasted 215k miles! (How many sets have you been through Gilbert?)
Glad I do all my own work as I imagine the current crop of ham fisted shop apes could really screw up the job!
With any kind of luck I will not have to do them again!
Been changed once at about 300k so likely to need doing again in the next year or two. Did them on the Ascot before selling it and got to do them on the red 4.0SE when I get time. They don't seem to have much slack in them but the boots are perished and split so were an advisory on the last MoT (should really have been a fail but as the tester knows me his comment was, "I'll put them down as an advisory as I know you'll do them"). I've got them, just waiting for a spare day or two. The first set I did, I spent a weekend at it and did one side a day. To be perfectly honest, getting the ABS sensor out without destroying it is the hardest part of the job.
After being quoted £420 to do one side by a local specialist and after a week was given a bill for £1080, it was that day when I decided that spending money on the correct tools and doing it myself was far cheaper that paying someone else to balls it up. I also work on the principle that if I do a job and have to bodge it for one reason or another, I know it has been bodged so know why if it fails. If I've paid someone else to do it and they've bodged it and it fails, I've no idea where to start.
Totally agree that getting the original abs sensor out is objectively the hardest part of the job. Factory didn't use enough coppaslip or equivalent on the assembly line to hold back corrosion for more than 5 to 8 years (at a guess). Even after destructive removal it was almost a workbench job to shift the remnants of the collet and corrosion from the holes on mine. Used lashings of coppaslip and the white anti-corrosion grease when I put mine back in about 10 years ago after doing the ball joints. Almost fell out last month when I did the nearside CV joint boot.
I have all three of the common import bearing press tool sets and found all the pressing cups and other gubbins needed. Pretty sure one would be enough but which one?
Unconvinced by the giant G clamp extractors. The one I got managed three but was clearly working hard and bent a bit under the strain. The fourth one defeated it completely. Made a knock off of the proper Sykes Pickavant 18771100 hydraulic extractor using a US Pro version of one of the cheap import "12 ton" rams sold as spares for various hydraulic extractors. Did the stubborn one effortlessly so I should have just made one in the first place as even the ones the giant G clamp managed would have been easier.
Shoulda done a batch.
Reckon Richards £1080 bill included a full Sykes-Pickavant set. Nearly £680 list these days, much cheaper then, but at least it does include all the press tooling for all the Land Rover and Range Rover models. Sykes-Pickavant want over £130 for the 12 ton ram unit alone when US Pro want under £30, albeit without the pointy bits for the end. Outrageous.
I was expecting an update on the EAS Clive......
The set I have is the big one with lots of different sized cups (at least half of which have never been used) and the big G clamp. I haven't managed to bend it yet, despite using a 4 foot bar on the 3/4" drive socket on the end of it. I got lots of pressure on then used a MAPP gas torch on the housing and it lets go with an almighty crack. After that initial movement, they press out fairly easily. If I was anticipating doing them regularly, I'd probably invest in a hydraulic one though.
RAVE says to use Silicone grease on the ABS sensors which is what I always use, but only because I've got a tube of it.....
Hoping for some time on the EAS tomorrow depending on progress with her ladyships list of things to be done. 5 months between visits means plenty of time for her to work one up. Might be Monday before I get a permit to work! So much easier home alone.
6 ft (and a bit) scaffold pole bent my G clamp ball joint extractor device just fine and even heat didn't help the stubborn one. I was really surprised how effortless the knock off hydraulic device was.
Got permission to play cars for an hour this afternoon after helping with the Christmas tree.
Comes up to normal ride height in about 10 minutes. Drops to bump stops fast and level in about 3 or 4 minutes. Almost too quickly to disable the self levelling before things start to move so looks as if the bags are OK.
Usual occasional clicks and puffs from the valve block as it comes up. Pump stops just fine as it should so it seems that the fast drop is a power-off issue as the pump would never be able to overcome a leak that big to bring it up. Assuming it is a power-off problem things should be working normally when running so it seems that at least the pump won't overwork driving home. However he stayed up for duration of a pee & stretch stop on the way up, maybe 10 minutes, so whatever cased the drop has gotten worse.
Valve block O ring recon time perhaps? If so who does a good kit these days.
To drop to the bumpstops in 3-4 minutes, it's one hell of a leak you should be able to hear it hissing. I would suspect the diaphragm valve. Unscrew the exhaust filter and see if there is air coming out of that.
I'll check that tomorrow. At least its only under power off conditions. No way would it pump up with leak that bad.
Had another play this afternoon.
Seems to be confirmed that system works OK when up and running on the road but has a significant leak bypassing the EAS solenoid valves when power is off and parked. Takes 10 to 12 minutes from starting before the flashing amigo stops, which is about right fr0m empty tank, suggesting no permanent bag side leaks.
So diaphragm issues are very plausible.
Paying more attention, just waiting and watching, I reckon 10 to 12 minutes is more realistic time to drop to bump stops. Probably a bit longer to fully empty the tank. Some flow of air out of the exhaust can be felt with filter removed but not enough to be vastly noisy.
Settles on right rear first followed by left rear then fronts together. But although the drive looks superficially level it's actually somewhat ske-wiff tilting every which way albeit higher at front. The EAS doesn't get involved whilst he is settling down. No solenoid clicks and leaving the doors open to inhibit the EAS makes no difference.
Wish I'd followed my instincts last time I got involved with the EAS and fitted an LED indicator to show when the compressor is running. Be nice to know that it's not overworking on the run back. Once home I can get some instrumentation involved for a better idea as to what's happening. Nanocom in the glove box not a great help here.
Time to rebuild the valve block methinks. 4x4 Seals talk a good game and package well but does the product match the appearance. The reputable diaphragm only kits seem to include an extra part and bolts. Are such needful.
Maybe ditch the 12 year old airbags and fit the new ones I've got in stock whilst I'm at it. Gets all the pain over in one hit. Mr MoT Man is muttering about the bags anyway.
I have included the EAS valve block and compressor rebuild as a service item to be undertaken every three years. I acquired a spare valve block and compressor off eBay many years ago and routinely rebuild the spares at leisure as 'ready use spares' and then swap them out with the in-service ones which then become the spares for rebuild. I use the complete valve block and compressor rebuild kit by X8R (includes replacement diaphragm) also available on eBay and never had a problem with them.
Thanks for the recommendation. I've got a spare valve block at home so might as well buy two kits and do that one as well.
$64,000 question is whether to try a rebuild up here with nowhere to work and only the on car toolkit, basic spanner roll, screwdrivers'n socket set, or run 300 miles home with an "only when parked up (so far)" fault.
Do you have a set of the Schrader valves that fit in the ends of the pipes (these https://www.ebay.co.uk/itm/274891528271) and a tyre pump? I've got a set that have lived in the boot of my car for many years so in event of a valve block or compressor failure many miles from home, I can put those on the 4 pipes to the 4 corners and pump each corner up individually. That at least avoids doing many miles on the bumpstops. In fact, I've got 2 sets as a former P38 owner donated a set to me recently, I could send them to you so you've at least got them if needed (or fit them and pump it up to something like motorway height and leave it). As long as the springs aren't leaking, which under the circumstances seems unlikely, they will get you home.
I've used both X8R and 4x4Airseals kits and there doesn't seem to be much to choose.
Thats really nice of you to offer your extra Schrader valve set but I've just ordered a new set for myself along with seal kits from X8R.
So, hopefully, I'm about as well prepared as I can be. At least I've got no running around to do up here.
