Thanks Gilbert; Ray seemed to think I probably wouldn't need to worry about shims, but I can do the checks once the work is done and go from there.
OB:
Mm, too much spendy, but equally, no point in doing a half assed job if I'm this far in. For all the above though it's still a lot less than Turners wanted, which means I can actually afford the cam upgrade.
I'm hoping front cover is OK; I'm sure Ray will let me know if not, but I've not had any oil pressure problems with this engine in the time I've had it, and oil gets to the rockers pretty quickly whilst just turning it over on the starter. Hardly scientific, I know.
Rocker wear; I'm not overly concerned here, as I'm not doing any more work on the heads at the moment. If I have to shim, I will, but hoping I can get away with it - the tolerances are pretty wide after all.
To add to the joyous spending, my dailys timing gear finally gave in the other day, so we're down to just the wifes car now. Five cars on the property and only one is a runner (and it doesn't exactly sound a1 at the moment). :(
                            Regards,
Miah
Near Glasgow
1997 4.6 HSE in Oxford Blue
