Just found this in the P38's history...
A tad eggspensive!!
LOL
i put my glasses on for that one
cheaper by the box full i recon :)
So it's had a new set of LPG injectors and still runs like a bag of shite? That makes it even better, a Profess install that was never set up properly and has since had the injectors replaced so it won't be calibrated for them. Get it to Simon!
Those Sonda Sensors are rare beasts :)
Sonda being Polish (Or spanish) for Probe, it suggests they have changed one of the lambda probes, but also both sets of injectors, 3 hours labour to change the plugs, leads, a lambda sensor, both sets of injectors, fill it up with gas and petrol and then to calibrate it seems quite quick. Even assuming the gas was onsite, its unlikely the petrol was, though could have been done on the calibration run maybe (why you'd take it there without enough petrol in it in the first place is another question entirely).
It was last service by PO..
It did indeed run like a sack of shit..
Personally defo rip off merchants, the wiring is a force to be reckoned with..
