Changed the pollen filters. yay!
Hi Morat. (or any one that can help in southern ontario :-( ...
could you please call me ANYTIME at 647 529 9276 im in bolton end of the 427 ,stuck with my 2001 P38 need advice and my be use of your NanoCom device to reset the immobiliser thanks Jonathan 647 529 9276
Not sure if there is anyone on here in Ontario, but what is the exact probllem and it may be possible to walk you through what you need to do.
He sent me a PM with the details, maybe there's a York in Ontario?
anyway:
installed yesterday a new 12V battery. car started geat did not use the FOB ,as the car is parked in doors
UNTIL THIS MORNING
my 2001 P38 FOB is not recognised by the car.
will not open doors.
when opened with kay the alarm goes off and the car will not start
disconnected the battery overnight
used the 1515 code
Range rover in Brampton( ontario) could not help..stated the car is too old :-(
If he's installed a new battery, the fob will have lost sync which is why it doesn't work. If he tried to open the door within 30 minutes of connecting the battery, it will have been showing keycode lockout so won't do anything or accept the EKA
I took my father out for cofee in the Duchess today. I was able to use access mode with confidence for the first time in ages :)
Access mode worked great for my Mom-in-law. Unfortunately she’s beyond that now.
Considering taking the LINLEY to its first public showing next weekend. All depends on the weather… vehicle has never been in the rain since its restoration…
British by the Sea, Harkness State Park in Waterford, CT.
Chance to see a unicorn.
it's good to sit in the rover and think it's nearly 30yrs old, it doesn't feel that it's that old. hope you do well at the car show.
Today I found out what a pheasant at 70mph does when it hits your headlight. It could have been worse though, it completely avoided the grille and bonnet although it took a fair amount of screenwash to get the remains off the windscreen.....
It even took both bulbs out!!!
Fifty years ago I was in hospital after an accident. The young chap in the opposite bed had been riding his motorbike when a pheasant crossed his path & hit him full in the face. His whole face was swollen beyond belief. He was lucky not to have died.
Happens more than you know...I was driving in my Granada 2.8 GL estate (company car circa1985) on the A7 from Carlisle to Edinburgh when a pheasant collided with my offside headlamp area .When I got to my destination a passer-by pointed out I had a dead pheasant stuck inside my headlamp housing..I let the local Ford dealership extract it and replace the unit and washing the blood of the front. At least it wasnt a deer... again !
My dashcam managed to catch it just before impact. 3 frames later (3/30th of a second) there's bits of glass flying out......
As my car is still blind in one eye and had agreed to take a mate to Stansted airport in the early hours of this morning, I decided I'd use the red 4.0SE instead. It hasn't done much more than the odd 60 mile round trip so checked it over and then thought it might be worth having a look at the HEVAC distribution motor. The book had been on for a while and the fault was showing as distribution blend motor stalled. I drove it a few days ago when the weather was hot and the AC was working well, the blowers were ramping up to full speed to try to cool the interior but all the air was coming out of the windscreen vent, none from the floor or face vents. So had the instrument cluster out to get to it. The usual cause of a stalled motor is stiff shafts and the distribution motor drives 3 instead of just one like the other two, so putting more load on the motor. A squirt of silicone oil is usually enough to get them moving freely but they need to be aligned.
As this is more pertinent to Max's thread https://rangerovers.pub/topic/3864-no-blower-air-to-windscreen, I've put the finer points in there.....
Pheasants are a pain in the headlights :( I worked over twenty years for an estate that shot pheasants so I've hit a few. The scariest one didn't cause any damage but it was a direct hit on the windscreen in front of my face. It detonated and I couldn't see a thing at 50 mph. Eek.
Changed the engine temperature sensor. Drove to Stansted to pick up a mate last night and noticed my temperature gauge seemed to be showing fractionally higher than normal. Rather than sit at 12 o'clock, mine has always sat at about 1 minute past and it seemed like it was at 2 minutes past. When I stopped I plugged in the Nanocom to see what it was running at to be told 51C.....
Errm, that isn't right. Looked at the stored faults and saw an interesting selection, like coolant temperature too low, and coolant temperature too low for closed loop fuelling. Now as my car has a single point LPG system that is almost totally independent of the petrol system (the only thing it uses is the throttle position sensor), those faults won't cause a problem with running. But I'd rather do something as I do very occasionally run on petrol and it would be nice to be able to see what temperature it is running at.
On the GEMS there's two temperature sensors, one for the gauge and one for the ECU. The one for the gauge is either an AMR5929 green top which is NLA or on earlier cars, one with a single wire connector and a second one for the ECU which has a black or brown top and feeds the ECU. A few years ago, someone on the dark side suggested that this https://www.amazon.co.uk/Bosch-0280130026-Temperature-Sensor/dp/B001CO2VU0 was a replacement for the green top one so I bought one. Only to find that it isn't, the thread is wrong so it won't screw into the manifold, so I bunged it on the shelf in the garage and left it there.
This morning, after the car had stood overnight, I checked the coolant temperature according to Nano and it showed 11C, yet infra-red thermometer showed the engine to be at 18C. Found the Bosch one and plugged that in with it just dangling on the wires and the Nano showed 17C. Infra-red thermometer showed it to be 17C in my garage so that made sense. Swapped them and can confirm that the Bosch one is a direct swap for ETC8496, the one that drives the ECU. The thread is correct, the connector is correct and the readings it gives are correct (confirmed by looking at coolant temperature on the Nano and comparing it with what the infra-red thermometer was showing). Took the car for a run and it was showing the normal 85-89C running temperature and when at 89C, the gauge was reading what I saw last night.
This week has been reserved for the long term preventative maintenance of Rangie which I do every 5 years or so although it started a couple of weeks ago with a trip to a 4x4 establishment in Bury St Edmunds who had the wherewithal to perform a complete auto box flush and refill.
Monday involved a complete drain, flush, and refill of the coolant system - quite pleased that the old coolant still looked like new which I took as a good sign and that flushing and back flushing with fresh deionised water didn’t result in anything but perfectly clear water. All hoses checked and looked to be in good condition. The system even refilled without drama! Aircon system inspected and still working fine and check on the running of both condenser/overheat fans showed them both to be fully functional even though they are rarely called into action. Air distribution system working with all flaps working properly.
Tuesday was main annual servicing tasks so oil/oil filter, air filter, pollen filters all replaced - although I noticed that the air and pollen filters were a lot more dirty than usual and only after some £3.5k miles since servicing last year and more detritus than ever in the air filter box! All screen and headlamp washers & wipers fully functional as were sunroof and door windows and rear view mirrors.
Wednesday involved the swap over of the refurbished EAS valve block and compressor including a refill of the EAS dryer unit with new dessicant and ‘o’ ring seals. Testing of airlines with soapy water showed no signs of leaks and leaving overnight at standard height saw no reduction in ride height. Compressor filled tank OK and shut off as normal and suspension went up and down through the full gamut of heights OK. However, when I first started up after being depressurised it tried to achieve access height which it did but the offside front airbag continued to fill and rise with no fault signal generated. It did respond to being told to get back down but seemed strange behaviour and this morning seemed to behave itself on start up. More strange behaviour as I took it out for a short test run everything seemed OK at standard ride height but on returning home I requested ‘off road’ (not extended) and the suspension didn’t seem to rise but the dash indicator immediately confirmed ‘off road’ level. It went back down through standard and access heights OK. Anyone explain this - solenoid issue or EAS control? Never had it happen before and not sure where to start looking!
Today is power steering fluid replacement - any tips on how to drain and refill the system efficiently gratefully received. Also it’s brake fluid replacement time - again any tips on how to perform this easily and efficiently gratefully received as the formal/official LR workshop manual procedure is a real ball ache!
Tomorrow will be drain and refill of the transfer box fluid and also partial drain of auto box to replace the strainer (filter is too strong a word for it!). I’ll save and reuse the drained (new) fluid to refill.
Then, hopefully, another five or so years of pain free motoring (if there is ever any such thing) with Rangie.
Suspension issue solved. Disassembly of the suspect solenoid revealed that the idiot refurbisher had omitted the small but important centre o ring on the base. Easy fix.
Fluid changes also now completed so good for another 5 years . . . I hope!
Rangie has been in the body shop for the past couple of weeks to eradicate the more serious body defects:
  • Roof completely repainted to rectify clear coat damage just behind the sun roof (looked like vortex damage - note to self, must slow down on the motorway) and flaking paint just inside the upper tailgate on both sides. New upper windscreen finisher and clips fitted.
  • The wheel arches immediately behind both rear wheels stripped back and all corrosion cut out and replaced with metal, welded, sealed, rust proofed and repainted.
  • Lower tailgate replaced with solid second hand unit, prepped, sealed, rust proofed and completely repainted.
Now I need to sort out other minor bodywork issues - minor nick on offside wing mirror housing, minor paint nick on front near side passenger door, cracks on radiator grill, minor bit of flaking paint on near side rear of the narrow lower front bumper trim.
Hopefully Rangie will then be OK for another 24 years . . . although I may not last that long!
MOT day. She went through, some advisories. The only worrying one is a front balljoint with play, which is a shame as I had those done soon after I got her... It's been a while!
