offline
Folks, I'm looking at buying a torque wrench. My current need is for a half inch drive type largish one (170lb ft min) and I'm not looking to break the bank. So, my question is - are there many reverse thread bolts on the P38? The one-way wrenches are cheaper, but how much use will I get out of the extra function?
Folks,
I thought The Duchess had forgiven me for failing to polish her every week but it appears this isn't so. Sometimes at the first start of the day she'll start straight up and stall out immediately. If I crank again there's a 50% chance she'll start and run fine for the rest of the day no matter how many times I stop/start.
If she doesn't start on the second hit, she'll crank for ever but never start.
Seeing as she has already had Plugs, HT Leads and Coils to fix the misfire (100% sorted btw) I'm guessing this is likely to be fuel. I think I've found the fuel test valve, and I have a fuel pressure test gauge thingy. I'm reading 50PSI as the correct fuel pressure for these beasts - but is there a spec for leakdown time?
Cheers,
Morat
I've just bought an 36mm impact socket from Amazon, and when it turned up it was 12 point. Is it me, or is that a bit unusual? I'm a bit confused overall as to why 12pt are the default for all sockets when 6 sided are less likely to round off nuts.
Am I being thick or is there an advantage to 12 sided sockets?
The Duchess has been off the line for a week or so because she decided that 6 cylinders are quite enough from cold. They do come back in when the engine is warmed up but it's a very nasty sounding idle/drive with 6!
Seeing as she has had new plugs and wires a couple of months back* and 4,7 are on the bottom half of the same coil - I'm wondering if this could be a coil pack issue. However, it seems a bit weird that only two of the four are missing. Or is that normal when a THOR coil pack starts to fail? Are they really two twin coils in a single box?
Or maybe it's something else entirely?
The codes are as you'd expect - catalyst damaging misfire 4, same for 7, then the multiple cylinder misfire error (logical) and sometimes adaptation out of range if I've been driving it on 6 for too long.
*which cleaned up a misfire on #2
My fronts are knackered due to poor tracking after all the front suspension components that were installed with only a "that'll do" set up.
The four tyres were bought as a set and are about 50% worn. If I get another pair on the front, will I be causing issues in the drive train? Should I get 4?
Cheers!
Videos like this make me jealous!
https://www.youtube.com/watch?v=KEiyLQaz94o&t=11s
I fancy a little mild green laning, but the local groups insist on recovery points... does anyone know what the most economical option is to provide decent recovery options front and back? Apparently the tow bar is a no-no.
Hi Folks,
it's all been running a bit smoothly :)
I was driving home last night and the ABS light came on. So, I tested the ABS and it still seemed to be functioning.. but definitely something to investigate.
Got home, shut off, restarted - no light. Hmm
So I hooked up the nanocom and of course there were no errors showing because I should have hooked it up when the light was still on.
Silly me
This morning, on startup, ABS FAULT on the dash soon followed by TRACTION FAILURE. I Checked the nanocom and got "Brake Switch Fault 1 time". I drove for about a mile and checked again "Brake Switch Fault 13 times".
OK - I cleared the fault, switched it off and on again* and all was peachy for the rest of the drive to work. No faults, not lights, ABS functioning (good news as I swerved round an oncoming lorry on the muddy road).
So it's an intermittent fault with the BRake Switch - is this the jobby under the brake pedal or is there another one hiding somewhere?
cheers,
Morat
*it's a perfectly valid test if you work in IT :)
After the rolling code/EKA debacle this morning, my just drove it and locked it on the key as the fob wouldn't work. I was surprised as it has always synced in the ignition barrel until now without any further effort.
However, doing the door lock waggle, key press dance (I'm not quite sure what combo it was, but it worked) re-synced the fob.
On the basis that there's only so much "Character" I can put up with on a car, has anyone ever replaced the RF receiver ring thing in the ignition switch?
I know we're far from a statistically significant sample but...
How long have people run their Rover V8s for?
If you have had headgaskets, cams, chains - or even new engines it would be interesting to know when those items were replaced.
It would probably be useful to know what mileage was showing when you bought the car. For example, mine was bought at 96k and it's now showing near 130k so I can't speak for anything that happened before 96k as it had no service history.
If you've got a spare £15k burning a hole in your pocket :)
https://tinyurl.com/sryttpb
Damnit, I went out this afternoon with my new plugs and wires... FFS how am I ever going to get my shovels in to the coil packs? I think it might be just plugs this time :/
Folks,
this is a bit of a pain. She's been grand all summer but now it's getting colder she's failing to start when cold. There was one time it wouldn't start and I cleared a security Serial link error and she started fine. I don't think this is related.
It started with crank, burble, nothing. Then crank burble, nothing. Then crank, fire - run (albeit lumpy to start with as cylinders chimed in)
As it gets colder it's more likely, crank, burble, nothing. Crank, burble, nothing, Crank crank crank crank nothing.
If you get lucky and it fires up, hot or warm restart is fine.
Currently looking at about 3C on the thermometer and she won't fire at all.
Faults on the nano
Multiple misfires (not surprising), and random upstream O2 no signal (occurred once, not present). I cleared then, they haven't come back but she still won't start.
Yes, plenty of fuel - both types :)
Where should I begin?
Lets play MOT Bingo!
I'm 99% certain I'll be getting new front tyres after the curious case of the Locked Viscous... but I thought I'd lob it in and chance it. I'd rather get the tyres myself but I ran out of time after the reminder popped up on my phone. I think I'll set a month's notice next year and put it on pay day!
The Duchess is being a little minx again!
After running perfectly as a DD for a couple of weeks she refuses to start. She has sometimes needed a couple of hits on the key when starting from cold, but has always started, nearly always immediately.
Suddenly she won't start at all. She cranks fine but there's no hint of any pots firing. Th8s is just a whinge really as I haven't bothered with any diagnosis yet but I'll post up results as I get round to them.
I'll start with a Nanocom scan, fuel pressure and try taking a spark plug out to test for a spark.
My money is on the CPS right now but that's a flat out guess until I have any data. I'll check before loading the parts cannon!
If anyone has suggestions on what to test, please let me know (apart from my head for still running this vehicle! 😀)
Folks, my fronts are pretty buggered due to driving 10k miles with a locked up viscous so they'll need replacement for the MOT. The rears are.. as you'd expect for 10k miles with plenty of tread and even wear. Am I OK to replace just the fronts or do I need to have the same rolling radius front and back? I'm wondering if having a difference would knacker the viscous again..
Thanks!
I'm not really a modeller these days but this is amazing!
If you can play Youtube in 4K and you've got a few spare minutes: https://www.youtube.com/watch?v=UPHASpKgRtQ
Wow!
After having to contemplate towing the Duchess behind Snog last month, neither Marty nor I knew if it would have been legal.
So, does anyone with towing experience (and I know we have at least one, eh Gilbert :) ) know whether it would be legal to tow a 2300kg vehicle on a trailer behind the same vehicle rated for 3,500kg (assuming the trailer was less than 1200kg, I guess).
Cheers!
Dumb question time again!
The battery on the Duchess is low, good enough to run the systems but not enough to crank. Can I hook up my (not particularly powerful) charger straight in there and avoid all the tedious window setting, radio codes etc?
It isn't a trickle charger, but seeing as you can hook up a whole car to jump start I don't see why it would be an issue except various google searches warn against this.
So, I thought I'd ask experts instead of Google :)
edit: very low :( 8.1V
With a day off I've slung a battery in The Duchess and I'm trying to get ready for the annual pilgrimage to Swindon so familiar to P38 owners. This time it's Radius Arm Bushes because I missed the meet.
I'm a little concerned setting off as she makes a nice loud cheep noise related to road speed. It's most obvious when coasting, disappears under power and for a Brucey Bonus there's vibration when coasting downhill. Steering left/right makes no appreciable difference. There's a reasonable amount of clonking during low speed manouvring too but I'm putting that down to the radius arm bushes. I did think it might be UJs in the driveshaft but wiggled the front one earlier (by hand) and it seemed solid side/side. It looked nice and fresh too, it that's any indication.
She's getting washed right now but when I get her back I'm going to get her up in the air (as far as I can with the standard jack). What should I poke/prod/pull when trying to diagnose? I'll try to get a video as well.
