offline
A couple of days ago, the dash told me the front passenger window wasn't set. I ignored it then tried to set it. It wouldn't move. Hmm. No biggie, will get round to it.
Then I noticed that the passenger wing mirror didn't dip when reverse gear was selected and.. oh, it doesn't move at all. Then I realised that the door won't unlock.
So, all the electrics in that door are dead. What should I try first, oh gurus? I haven't done anything silly, like fill the door with water or fix something that wasn't broken or anything like that.
I was filling up the Jeep and up rolled a rather tidy looking x reg Vogue in that dark metallic red on what I think what lightstone. Turns out the guy has had it since 2005, it had a rebuilt engine after HG failure at 107k and now has 117k. He's also looking at "tidying up a couple of bits" before getting an L322. I nearly asked him what he wanted for it!
Sadly his talk of how it's now a classic and going up in price sounded the alarm bells, even if I did have the space, money, time, etc etc :)
Still, it was nice to see another good looking one :)
Hi, just had a call from my wife who needed talking through the EKA unlock procedure. I sense strife when she gets home!
There is only one fob with the car, and it seems flakey. Sometimes the key fob seems to be transmitting fine (flashy red light etc) but the car won't unlock. You can hold it next to the rear windows, point it at the antenna, dance on one leg - nothing.
So you open the door using the key and the BECM demands the EKA before allowing the engine to start.
What's going on? I've had it happen to me when I'm sure I haven't pressed any fob buttons at all between lock and unlock, but I will admit it never seems to happen immediately after locking.
I just drove to Swindon from Yorkshire so I can help* Marty replace the heater core in The Duchess.
The gauge on the dash showed 1 degree pretty much all the way and my feet had nearly fallen off by the time I got to the hotel.
Holy crap, I can still feel my toes warming up, three hours after arriving!
If it wasn't for the heated screens, it would have been lethal. As it was I had to wipe the drivers window when I got to a roundabout. I'm looking forward to a nice warm drive back North!
  • lift/pass/make tea as directed
... changed a headlight bulb, one of the H4s AND it was the driver's side one which is slightly masked by the uber-battery.
I'm feeling smug :-)
Gordon,
not sure if you've noticed but Firefox is freaking out over the site cert....
Cheers!
Morat
My engine bay was lovely and clean not long ago but some enthusiastic splashing through muddy puddles has made it a bit grubby. The final straw was following a slurry tanker today which was as slurry-tight as it should have been and the whiff is now pretty grim.
Can I get away with just hosing it down? Do I need to take any precautions? I know some cars really hate water under the bonnet (I've owned a Fiat in the past!) and some don't seem to mind. I'm thinking that a bucket of dilute degreaser, some scrubbing brush agitation and then a good rinse with the hose would be my plan A but I thought I'd better check.
What is the collective wisdom of the forum?
http://www2.autotrader.co.uk/classified/advert/201611149756915?sort=price-asc&fuel-type=Petrol&make=LAND%20ROVER&model=RANGE%20ROVER&onesearchad=Used&onesearchad=Nearly%20New&onesearchad=New&advertising-location=at_cars&radius=1500&postcode=yo606pt&page=3
Apart from the weird looking exhaust, the wrong alloys, the "easily repairable DVD" and the LPG system of unknown provenance... I'm still weirdly drawn to the greenness of it!
Also it's 168 miles away, which is about par for the course whenever I buy a new car!
Is there a correct tool for removing the back of the keyfob? I'm totally unable to remove it without knackering the slot which means I need to buy a new one each time for fear of being left with something that will be stuck forever.
Also, I've been getting intermittent Key Battery Low warnings recently, and now the damn thing won't work at all. No red light, nothing. I finally got the back off and tested the batteries at... 6.02V. Gah.
The contacts look to be springy and in the right place, is there another fault that could cause this? (I suspect there will be several options).
Time to bend over for the Landrover dealer and shower him in money for a second fob :(
More fun!
I came home late from work and noticed a familar vehicle parked up at the entrance to the village. Uh oh. The Range Rover has decided to release its coolant, not sure if it's all coming from the rad, but the slam panel had a good coating of coolant and the little plastic stub for the expansion bottle is still leaking. My Wife parked it up within a hundred metres or so of noticing the red light come up on the dash (She's not sure if it was temp or level, no beep) and the temp gauge was in the red. She had checked it a mile before hand at it was fine.
So, hoping it hasn't popped a head gasket....
I'm going bypass the leaking heater core and replace the radiator. I've had good results with Nissens in the past, are there any specific recommendations for P38s?
@Marty - guess it wouldn't have reached you anyway!!
Gordon mentioned he might start a thread like this, but he hasn't yet. So without wishing to step on toes, here's my attempt.
What could we attempt as a group?
I'd be in for:
Headlining
Possibly Ball Joints
Slung it in for an MOT at erm... short notice this morning
The garage (excellent work, but notoriously picky on MOTs) came back with rear pads (not a surprise) and front to rear brake pipes x2 6 hrs to replace.
Am I being rinsed? I know these can be a git on some cars but I see varying reports from 1.5hrs each.
Folks,
my wife has failed to start the Range Rover again!
I'm not infront of the vehice right now (being at work) but...
If you can't open the car on the remote and then open it with the key would you expect the alarm the chirp? (and then do it again when you close the door?)
She bottled out and didn't want to try and start the thing in case the sounder went off properly.
Is this likely a case of flat batteries? (they're only about 4 months old)
Or something more sinister?
Map CD in forum Electrickery
Marty, Chris,
I've got a freshly burnt 2012 CD for Chris - but is it worth me sending it if Marty wants me to test a 2015 version which I could copy?
I'm happy either way, just let me know.
Cheers,
Miles
Two steps forward.....
I've found out what the noise is underneath the Range Rover. How bad a job is this? I've got someone who will do the work but I'd like to know how many hours I'm looking at. It sounds like a reall ballache to get that far into it all :(
Cheers
Morat
After Summer Camp, I asked Marty about some of the things that he could sort on my (my wife's) Range Rover and we set a date for last weekend. It turned out to be quite a busy time... for Marty at least :)
A lot of my original list is now gone!
The heated seats now work, and have the uprated 50degree thermostats, which are very popular.
The HEVAC unit now shows all of its pixels. Also, it is LED illuminated which doesn't quite match but is very clear and pleasant to look at.
The drivers door lock was replaced - I knew the switches were dead because I couldn't enter the EKA the first time I got locked out. This forced me to buy a Nanocom (which I don't regret) but now there's a new door lock which even has superlocking.
Then when we were scratching our heads and watching the EAS go up and down, we realised that it was still going up and down with the passenger door open. Duh.. shouldn't be doing that! Another door lock solved the problem, there's something eating microswitches round here :(
The EAS was a complete bastard. Marty was flicking through the circuit diagrams at ludicrous speed but the only thing that stood out on the Nanocom was that the Hand Brake on/off input was always showing ON. Weird. There wasn't any known reason why that would make my EAS only ever go up but it was definitely a fault so it was worth fixing. Frankly confidence in the vehicle was quite low. Driving at 70mph and finding yourself in High Centred mode is not very pleasant because the thing handles like a baby Giraffe on the first corner.
Marty narrowed the fault down to the Pink/Black wire which runs between the BECM and the EAS ECU. We were running short on time so Marty disconnected it and I tested it on the way back to sleep that night. It worked! For the first time in ages the Rangey dropped to Motorway height when it was meant to. The only downside was that without the handbrake signal, Access Mode isn't possible. We did toy with the idea of leaving it like that but neither of us would have been happy with an unsolved mystery.
The next day, when he started to trace the wire, he found the end of a self tapping screw coming up from underneath the vehicle into the wiring loom on the right hand side ahead of the BECM.
Great. Some soldering and shrink wrap later there were four wires repaired (including the handbrake wire) and full EAS was restored. RESULT! sadly we then wasted a couple of hours because of faulty LR manuals which indicated that the handbrake signal was still incorrect. I got to see inside my own BECM (which is a bit like watching your own open heart surgery) but eventually it was certain that the BECM was working fine.
That cost us the chance to have a go at the faulty blend motor, but by that time it was clear that I've got bigger problems behind the dash. The carpet under the drivers footwell is soaking and pink. Uh Oh. I guess that means the dash is coming out pretty sharpish* for a new heater core, so the blend motor and a sensor can wait till then. Hmmpph :(
In other bodging news, Marty took the chance to change some bulbs in the instrument cluster. The ABS and TC bulbs were fine.. just taped over by some previous MOT dodger. Great.
Then to top it, on the way back a new and expensive sounding noise appeared from underneath. It could be a CV joint... I should find out tomorrow.
But massive thanks to Marty for putting his brain to work on The Duchess, which is now a far more complete motor than it was before. I hope we'll be able to get one of his Audi heater cores in it some time, but I think I'd better investigate the running gear before taking any more motorway trips.
*sharpish is realistically a couple of months. Lets hope nothing goes badly wrong by then.
I've burnt that SatNav disk - just need your address :)
cheers!
Morat
Is this a flat battery?
I get gearbox fault, eas fault, traction failure, abs fault and it won't start..just click click click with the dash lights dimming in time.
Help!
Gilbertd :)
I wonder if you could cast your expert ear over the following recording?
http://www.lard.me.uk/nastynoise.wav
Something really horrible is interfering with our work radio repeater. It's located in a Farm Yard with adjoining works yard and joinery shop, so there's loads to go at and I can't think of anyone with more experience who might be able to narrow it down a little bit!
I can't stretch to £350 a day and free F1 tickets but I could manage a pint :)
Well it's not bad, but it's not perfect....
The general symptoms are:
Low MPG (2.8/-2.9 miles/litre on LPG)
Hesitation on Petrol at about 3500 rpm on hardish acceleration (seems OK on WOT). No hesitation on Gas (maybe because the LPG is richer?)
I'd had a code showing a sensor fault for the upstream o2 bank1, which I tried to change but I couldn't undo the bloody plug*. So, just in case it was throwing the code because the LPG was running too rich for the ECU to lean it back out I reset the adaptive values and took it for a drive on Petrol only to see what happenned.
Immediately after reseting the adaptive values, the idle went to hell. Nasty and lumpy. It took about 5 minutes to get back to normal. Then I took it for a short drive. It was weak, very weak but it kept running and slowly improved.
Codes: Adaptive values out of range, both banks. Knock sensor (1 time). Strangely, I didn't see any misfires recorded on the misfire screen.
I cleared the codes and did ~35 miles on petrol on back roads and tried to get into every part of the rev range in low, medium and high throttle openings. It started out pretty grim but did settle down to being properly driveable, with the exception of the 2/3 throttle hesitation at 3500-4000 revs. You have two choices at that point, back off and let the 'box change up so you can pull away again at just below kickdown or just floor it and it moves on again.
Finally I parked her up and checked the codes again. This time just the "adaptive values out of range, signal too high" for both banks.
So.. I don't think the 02 sensor is necessarily bad. I've been watching the live output and they both seem to switch between the same ranges (about 0.01 to 1.4). Bank one did take a while to read anything from cold(ish) after the first reset - I don't know if that is enough in itself to require a swap. I have the part if necessary, just need to get it up on a ramp and get medieval on it's ass!
Does anyone have any suggestions? I can get whatever info is required from the Nanocom, I just wish you could tell it to "dump everything" to the SD card from Motronic, but if it does that I haven't found the option. Personally, I'm leaning back towards MAF again.. but I don't know these engines - yet 🉑
*I really suck at this :( I couldn't fit my hands far enough up the gap to get a decent grip on it, and I wasn't strong enough to do it with fingertips.
