offline
Help!
My wife was driving and after returning to the car she said the alarm sounded when she tried to start it. I don't know if she locked it. Possibly not.
Now I can operate the door locks with the fob but the engine won't crank. There's no eka warning on the dash. I tried Eka unlock via the nanocom but no change.
I also (foolishly?) tried to unplug the siren and found out is IS battery backed...
Is this the loss of sync thing? Is there anything I can do?
.> Worst case, reset the fault, manually pump up the system so it's riding on air, and then pull the ECU connector or delay timer relay - it will then have air in the springs, but not control the valves to let it out... then we can look at it when you get here :)
A couple of bits of wire in the ECU connector will also just give an EAS MANUAL message on the dash, rather than all the beeps and hard fault messages. .<
OK, this is a bit advanced for a biff like me.
The dash isn't giving any messages. There's nothing in the EAS fault memory apart from 1x "invalid fault code" which I can clear but without visible change.
The EAS christmas tree is solid on the access mode and flashing on any other mode you try to select because it's just not rising (ooer).
Compressor runs.
I'll switch it on tonight and stick my head underneath to see if I can see/hear any leaks.
How do you pump up the EAS manually? I'm guessing that if there's a leak, I'm stuffed until I can sort that but if the compressor has failed then I should be able to run as Marty suggested.
Mrs M reported that the Traction Control error had returned. I wondered if the ABS sensor had vibrated out again, but there was no ABS warning. So, I checked through the nanocom and found only one error "invalid fault code" on the EAS system. I deleted it and the TC error on the dash dissapeared. So it looks like there's something strange going on in the EAS.
So, I had a play with the EAS in light of what Gilbertd said in my other thread and confirmed it won't lower to motorway position automatically. If I press EAS inhibit and select motorway it'll go there. If then switch off EAS inhibit, the EAS stays in motorway when above 50mph and returns to High as normal when you drive through a village at 30.
Finally, one of the codes that I've seen in the Motronic was "rough road signal implausible". Unless anyone has a bolt of inspiration I think I might be asking MartyNZ about EAS ecus in July....
Whaddya reckon? :)
So, I said I'd bought a Nanocom :)
First on the list was Motronic, so I thought I'd start there. There were a LOT of codes, so I cleared them all and ran it again. There were fewer codes the next time but some worrying ones like "Multiple cylinder misfire" and "adaptive values out of range". To be honest, I could feel that through my arse - especially on cold idle on LPG.
So, I switched off the LPG, reset the adaptive values and went for a drive on petrol only.
These are the results.
NANOCOM - MOTRP38.APP - MOTRONIC fault file
P1592 = ROUGH ROAD SIGNAL IMPLAUSIBLE
DRIVE CYCLE A
OCCURED 1 TIMES
SIGNAL INVALID
FAULT IS CURRENTLY PRESENT
FAULT DETERMINED AS PERSISTENT
FAULT DOES NOT CAUSE THE
MIL LAMP ACTIVATION
P1000 = LAMBDA SENSOR UPSTREAM
CATALYST BANK 2 DRIVE CYCLE C
OCCURED 1 TIMES
SIGNAL INVALID
FAULT IS NOT CURRENTLY PRESENT
MIL LAMP ACTIVATION
P0172 = MIXTURE ADAPTION FACTOR FRA
BANK 1 DRIVE CYCLE C
OCCURED 1 TIMES
SIGNAL TOO HIGH
MIL LAMP ACTIVATION
P0175 = MIXTURE ADAPTION FACTOR
FRA BANK 2 DRIVE CYCLE C
OCCURED 1 TIMES
SIGNAL TOO HIGH
MIL LAMP ACTIVATION
I'm guessing I need a new O2 sensor, somewhere. Could someone possibly enlighten me as to which one that is? :)
Also, what is the rough road sensor? It sounds more like EAS than Motronic to me, but if you have any hints I'd be grateful.
Or just point me at the relevant section of RAVE, I'm still a complete novice looking round that monster!
Other known faults on the vehicle at the moment:
  • ABS/Traction failure on dash - just had a new front left wheel hub after bearing collapse so I'm guessing that sensor might be toast - have yet to code that on the nanocom because it seems to need to be done on the move and I had a 4 yo on board.
  • Blend motor failure, not bothered with that yet.
  • Non heating heated seats
I've no idea if these are relevant but until I know enough to discard unrelated symptoms I'll list them just in case.
Miles
Folks, this is getting more serious :(
This is a 2001 (Y reg) 4.6 Vogue which is parked up at the garage after the battery went flat while it was waiting for parts.. Today the owner charged the battery, hooked it up and left it so I had time for the 30 minutes timeout to elapse before I got there.
I can open the door with the key, the hazards come on (the alarm doesn't sound, maybe it's broken?) and when I try to start it I get
"Engine Disabled, press remote or enter keycode." on the dash
I can mess around with the other stuff and set the windows etc, but I can't start the engine or use the remote.
I've tried entering the EKA in the driver's door lock (all doors, tailgate, bonnet closed, door handles pushed in) but no joy. In fact, I entered it 4-5 times and nothing happened at all no lockout warning on the dash, no beeps, clicks or anything. The central locking doesn't work on the key or the remote.
I tried resynching the remote using the door lock method - (key in, press unlock, turn to unlock, turn to centre, release button, press lock, turn to lock, return to centre, release button) - no joy.
I also read somewhere that post 99 they should "easy sync" in the ignition - couldn't make that work although I wasn't sure of the procedure.
I've got nothing!
Can anyone suggest some diagnostics or next steps?
thanks
Miles
Annoyingly it died at the garage where I was getting the wheel bearing done. Garage is clueless on P38 electrics (like me!)
I've found the EKA procedure and I'm hoping to go down there and sort it out. The garage is charging the battery overnight so hopefully it'll hold long enough for me to sort out the EKA issue and get it onto the guy's ramp so he can change the hub and brakes.
So.. I don't think I'm going to trust that battery any more. The usual online suspects don't seem to have anything man enough in terms of CCA and most of them are at 70 aH which doesn't seem enough.
So, good old Hellfrauds...http://tinyurl.com/zda6j5m they seem to have a reasonable selection. Should I just go with the £99 one? I'm thought I read somewhere that the P38 prefers a lead acid to calcium, but that might be BS!
Arnotts in forum Oily bits
Folks,
apart from being ridiculously expensive, are the Arnott Gen3 bags worth looking at? I like the idea of the ride being firmer when lower instead of firmer when higher - but I've also read some stories that they're not the most durable parts.
Does anyone have any experience? I'm not really bothered about the extra 2" ride height although if I had the bags I'd probably slowly collect the other bits needed to raise the offroad height (shocks, rear height sensors).
Well, technicall my wife was driving....
Turns out that the slightly vague front end and possibly the ABS/Traction faults were down to a knackered front left wheel bearing. I've never heard of a wheel bearing collapsing before, they've always given plenty of moans and grinding noises before they got that terminal but this one collapsed to the extent that it took out the brake disk and left the steering all cockeyed!
Garage has recommended a new hub. Are there any OEM equivalents around (or OEM) that you guys would recommend? I had a look at Island 4x4 and they want £175 for an "OEM QUALITY" HERE I'm happy with the price, if the quality is good.
Do you guys have any recommendations?
thank you!!
Miles
Hi Folks,
just thought I'd swing by and see how things are doing.. oh and to show off that I've just had the RR converted to run on LPG which is a huge relief to the wallet :)
It was done by Simon at LPGC (Gilbertd will know who I mean) who seems to have done a really nice neat job.
50p a litre? mines a double :)
Cheers all,
Morat
Hello, since we've had the Rangie (about two months) there have been 3-4 times when the gearbox has failed to engage. The display on the dash is normal and agrees with the gear lever position but you end up revving and going nowhere. So far is has always engaged gear on the second attempt and behaved itself for the rest of the trip but I'd like to check to see if this is the beginning of anything scary or whether there's a simple explanation (or whether it's normal?).
Could someone let me know if I should start saving up? :)
Thanks,
Miles
Folks,
I've searched and searched but there seems to be a lot of variables on this topic. My Rangie is a 2001 Vogue with navigation and what I believe to be the upgraded HK stereo (at least that's what the advert said). It is all still working and I'd ideally like to keep it that way but is there a way to fit a bluetooth module to let me pair phones for hands free calling and music streaming? For the record our household is all Android, but that shouldn't make a lot of difference for BT. I hope :)
All bright ideas gratefully received! Although I suspect the answer is likely to involve a lot of scary wiring :)
Cheers!
Miles
Ey up! in forum Opening time
Well there I was, wondering if I dare post a question on a certain other board without getting my head ripped off and Gilbert dropped me a PM.
So here I am :)
I'm a newbie to Range Rovers, I've had a couple of Jeep Cherokees (XJ) and was looking for a nice WJ Grand Cherokee Overland (with the 260 HP 4.7) but couldn't find a nice one. While I was looking I came accross an ad for a 2001 Vogue in Epsom Green with Lightstone seats and pretty much had to have it!
Having almost sleep walked into P38 ownership I've woken up with a bang and I'm a bit nervous as to what I've got myself into, but so far she's been a great ride. Once I'm happy that I've got a "keeper" it'll be getting an LPG conversion so I'll have some money left for food, heating oil and other luxuries!
I'll be the one asking the questions for now, hoping to learn a lot from you helpful types so THANK YOU for taking the time to put this board up. May I be the first to suggest a real pub someday? :)
All the best,
Morat
