An update and to answer some of Dave's questions. It's in and it works, sort of..... Noticed the difference between the 4HP22 and 4HP24, the actual gearbox section of the 24 is 15mm longer but the tail housing is 15mm shorter so the overall length is the same. However, that means that while the overall length of the box is the same, the tail shaft sticks out 20mm beyond the face that the transfer case bolts to rather than the 5mm on the 22. After a bit of head scratching and measuring, realising that as the transfer boxes are identical and interchangeable, the only difference would be how far into the splines in the transfer box input shaft that the output shaft of the gearbox slides into. Measured the splines and found that they are easily deep enough to take the extra length. So as well as the other differences, the length of the splined connection between the two is greater on the 24 which, presumably gives it more strength there too.
So, after a bit of a struggle, the transfer case went back in and was bolted up to the gearbox. The main problem we had with that was supporting everything. With a large, 20 ton (overkill I know but it was given to me by a truck driver years ago and it's nice and big), bottle jack under the end of the gearbox where the mounting plate would go and the transfer case on the bracket sitting on the trolley jack, the bottle jack wouldn't allow the trolley jack to get close enough. Not wanting to support the weight of the gearbox on its sump and risk denting it, Bolted a length of steel angle to a spurious tapped hole in the side of the gearbox casting to take the weight. The other problem was getting the transfer box on the trolley jack under the car. I'd put my EAS High calibration blocks in the bumpstops so the suspension wouldn't drop and jacked the front wheels up until I could get ramps under the front wheels. The front wheels were then strapped to the ramps with the same ratchet straps used to secure cars to a trailer so it couldn't roll off.
But, it still wasn't quite high enough to get the jack with the case on it under the car. So it was Nanocom to the rescue. Plug it in, go to EAS, turn the compressor on and run that for a couple of minutes, then open the front and inlet valves so the front rose up, do the same at the back and we had at least another 3 inches of clearance. Anyway, transfer case in, and realised it would be easier to bolt up the front propshaft before the crossmember went in as access is easier. I know a lot of people have a problem getting a socket onto the propshaft bolts but I decided to replace the original hex head bolts with Allen headed bolts and had bought ones of the correct size and thread (3/8 UNF) along with new Nyloc nuts. That way all four can be done up without having to rotate the propshaft. Then it was time to refit the exhaust and crossmember. The exhaust was simple enough to put into place but the crossmember put up a fight. I'd had to use a crowbar to get it out and it needed a club hammer to get it back in, gearbox mounts (new ones) fitted and bolted up and we could finally remove all jacks from under the car, Exhaust bolted up properly, rear prop in, with more new nuts, prop guard on, connect the oil cooler and dipstick pipes, connect the wiring plugs, fit and calibrate the XYZ switch, poke the handbrake cable back up through it's hole in the floor and it was time for some fluid. At this point Dina came outside and asked how we were getting on, so I gave her a stepladder, a small funnel and two 5 litre cans of nice new Castrol ATF (at around half the price from Opie Oils than Eurocarparts own brand stuff). At one point she poured it in faster than the funnel could cope with so with ATF down the side of the engine and one exhaust manifold I knew it was going to smoke and smell a bit once it was started.....
Finally the time came to start the engine and see what happened. The inevitable cloud of smoke from the ATF all over the exhaust manifold and lots of greasy handprints on the exhaust but other than that, all seemed fine. The 4HP24 holds 11 litres from empty but there must have been a litre in there as with 10 litres, once running and checked, the level was smack in the middle of the min and max marks on the dipstick. Although the dash was showing Gearbox Fault and not displaying the selected gear in the message centre. Not the XYZ switch as the LED next to the gearlever was displaying correctly. Checked the fault code and it was giving an Engine Torque Fault, cleared the code, ignition off then back on again and the selected gear display was back and no Gearbox Fault. Started the engine and after it had run for around 20 seconds, the fault comes back. OK, but does it work or is it in limp mode? The answer is, it works, all gears engage, torque converter lockup happens and kickdown works but the changes, particularly down changes are harsh.
Checked in RAVE and it lists a fault of Engine Torque signal out of range with the affect being harsh gearchanges but no limp home mode. So that is what I have. A torque signal is sent from the engine ECU to the gearbox ECU. Thinking that maybe we had damaged the wiring (even though it is all in a protective flexible conduit) when putting the gearbox or transfer case back in, measured for continuity between the two ECUs. No problem. Then checked for a 12V PWM signal from the engine ECU and my cheapo Chinese graphical meter showed a waveform although it appeared to be showing a much lower level. Being fortunate in having another car, the Ascot, sitting there, checked that and found a completely different waveform and at a higher level too. Checked the two gearbox ECUs and found they are different (mine is AMR5493 marked 4.0 while the Ascot has an AMR5496 marked 4.6), so pulled the ECU out of the Ascot, tried that and this is where things start to get really weird.
With my original one, if I clear the fault then read the data, I get an engine power reading of around 45 at idle rising as the engine is revved, a battery voltage of 10.6V (?) and the gearbox mode as Economy (the ECU supports Normal, Economy and Sport modes although the P38 only uses Economy and Sport). After the engine has run for around 20 seconds, the power reading goes to 236, the gearbox mode goes to Normal, the dash beeps, Gearbox Fault comes up and the gear indicator goes out. In this state I get the harsh gearchanges. On the Ascot, with a 4.6 engine and 4HP24 gearbox, I get power of 52, again rising with revs, 13.8V battery voltage and gearbox mode of Economy. With the Ascot ECU on my car, I get power of 45, 13.8V and Economy mode for the first 20 seconds then the power reading changes to 236 but the gearbox mode stays at Economy, no Gearbox Fault and gear display stays on the dash. Driving it like that, it drives perfectly with super smooth gearchanges both up and down the box, kickdown works and so does Sport mode. Brilliant I think, cracked it but as soon as I exit the displayed data on the Nanocom, the dash beeps, Gearbox Fault comes up and the gear indicator goes out.
So, the situation at the moment is that with the Ascot ECU in and the Nanocom connected and displaying the gearbox inputs, it works perfectly (even if the engine power figure seems odd). The Ascot is an earlier car (96 model, VIN TA337218 showing a build in mid 96) and having checked the data on the gearbox in it, it is a model 030 061. The gearbox I have fitted is an 030 064 so would be from a 98 car which should have an AMR5692 ECU. It might be that all I need do is fit the matching ECU but I'll give Dave at East Coast Range Rovers a call in the morning and see what he can suggest as he has swapped gearboxes in the past and they have been a simple plug and play job.
Anyway, to answer one of Dave3d's questions, once the propshaft, crossmember and exhaust are off, flex in the engine mounts will allow it to drop down but as the gearbox mounts are attached to the crossmember, it'll try to sit on the floor. That's why RAVE tells you at the beginning of the gearbox removal process to remove the upper fan cowling, so you don't break the fan as the front of the engine rises. On the diesel I don't think you need to remove the crossmember to get the exhaust front exhaust pipe off, so leave it in place (in fact, I'm not even sure if you would need to remove the exhaust downpipe as it is on one side and not both as on the V8 although it might make access easier). With the propshaft off, remove the U shaped shield that is there to stop the propshaft flailing around if a UJ breaks (not that one ever should if greased regularly). There's 6 bolts holding the transfer box to the gearbox and the top two are a bit of a pain to get to, multiple socket extensions and universal joints needed. The first time I took mine off, I had to resort to using an Irwin bolt extractor (https://www.amazon.co.uk/Irwin-Bolt-Grip-Remover-Expansion/dp/B000QW6K8I) to get a good bite on them. They are flanged head bolts so the actual hex isn't that deep. My transfer case bracket is a couple of lengths of angle iron that fits onto the lugs where the bolts go and was made up with the case in the car so the bottom of it is horizontal and a suitable size socket to fit into my trolley jack bolted and welded to the bottom of it. That fits onto the bottom of the case with a ratchet strap around it to hold it in place. If I was to make another, I'd make it so a couple of the bolts on the case can be taken out and used to bolt the bracket to it rigidly. That way the transfer case can be unbolted, the bloody annoying and a real pain to get to, breather pipe can be disconnected and it can be slid backwards. Once clear it can be lowered on the jack and pulled out from under the car. Refitting it is the reverse but a couple of long M10 bolts to fit into a couple of the bolt holes to use as guides for it to go back in are useful.
- '98 Ex-Greater Manchester Police motorway patrol car, Range Rover P38 4.0, in white with a not very recently cleaned cloth interior
- '96 4.6HSE Ascot because you never know when you might need a spare
