Seems that the spec changed as and when they felt like it. That latest one is badged as a Vogue but doesn't have the body colour bumpers, wooden bits on the steering wheel or wooden gearknob but does have the wooden centre console surround and contrasting piping on the seats. This one http://www.ebay.co.uk/itm/Range-Rover-4-6-Vogue-/222297678422 is also a Vogue but does have the extra wood bits This one http://www.ebay.co.uk/itm/RANGE-ROVER-P38-MKII-4-0-V8-HSE-AUTO-1999-EXCELLENT-INTERIOR-AND-AIR-SUSPENSION-/272424509752 is an HSE but has body colour bumpers, this one http://www.ebay.co.uk/itm/2001-LAND-ROVER-RANGEROVER-4-0-HSE-THOR-METALIC-GREY-/331993292434 is an HSE but does have the wood on the steering wheel while this one http://www.ebay.co.uk/itm/1999-Land-Rover-Range-Rover-4-6-V8-auto-HSE-/252580464689 says it's an HSE but has body colour bumpers and the wood steering wheel and gearknob (although the red carpet suggests it's actually a Bordeaux)......
I imagine they were using up parts when they got to the 2001-2002 production, so the trim (and maybe even the badging) is a sort of lucky dip depending on what they had left in the bins.
The May 02 one http://www.ebay.co.uk/itm/262690497784 doesn't even have fog lights!
I'm thinking I might widen my search net.
If I can pick up a non-lpg 4.6 Vogue for the right price, I could just do my own LPG install using something like this
http://www.ebay.co.uk/itm/Range-Rover-P38-2001-HSE-BRG-Multi-Point-LPG-KIT-/172323900800?
How hard is it to get them certified if installed by a non lpg certified tech (AKA me!)?
Weird, although my blue one is an SE and although it has front fog lights, they've been retro fitted as there's no switch on the dash for them so they don't do anything. Gordon's is badged as a Vogue SE so I wonder what spec his is?
I've not yet seen any Vogue SE's that have the same specs!
Wood trim varies right through to Piano Black, some have matching gear knob, others don't, some even have what is supposedly a unique factory wheel fit
Avoid secondhand kits and don't go for either BRC or Prins as they tend to be approved supplier only so you'll have difficulty getting the software to programme them Something like this http://tinleytech.co.uk/shop/lpg-kits/bigasaeb-8-cyl-sgis-kit-up-to-380-bhp/ would do the job admirably. Anything that uses the AEB ECU is definitely the way to go as it is known by everyone. That would be OMVL, Bigas, Romano, Zavoli, Emer and probably a few more I've missed. Getting it certified shouldn't be a problem, although most LPGA approved installers will charge you £100 or so to inspect and certify it. Many insurance companies don't insist on it being certified and DVLA will change the V5 if you send them the invoice for the kit.
Makes it a bit more expensive at around £920.00 fitted and certified, but I suppose you have the pleasure of working with new clean parts.
My insurance company do insist on the certificate, and to be honest, I'd probably want it checked over by my local accredited tech anyway.
It's not that I don't have faith in my own workmanship (I can do a lot better than the RIP install quality on my current car), but just to be independently told "it's right"
Here's the Code of Practice that an install needs to meet to pass inspection https://drive.google.com/open?id=0BzxqPPypF5J5WVlUOEhUSUJMTTA
This is the King installation manual https://drive.google.com/open?id=0BzxqPPypF5J5WkduYlJLMzJjWEk and this is the Zavoli manual giving a bit more info on setting it up with the software https://drive.google.com/open?id=0BzxqPPypF5J5QS1fUjVyZG03aXc (King and Zavoli both use the AEB ECU so are the same).
Ta!
Bit of light reading between P3 and Qualifying for me then.
I'd go with a new kit, and frankly I've gone with getting a decent installer to do the whole damn lot twice now and the LPG still pays back in a year. There's little more frustrating than a bad LPG install. If you've got the skills to install, fine but it's a hell of a lot easier to learn on something that worked once than to go from scratch.
Just make sure than when you go to attach the line from the tank to the engine bay that you are screwing it in AWAY from electrical looms in the vehicle... Morat will be able to sympathise with that ;-) Likewise, when I first got my RR, I found a self-tapper through part of the wiring loom... can't have made a lot of difference in my case as it had been there for 4 years before I found it... But again Morat can testify to what can happen...
Absolutely anything can happen! It's a great game. You wear a blindfold while someone cuts (or shorts) one or more random wires in the loom and you get to diagnose and fix it!
I cheated and called Marty :)
Here is a cheap one, OB!!
http://www.ebay.co.uk/itm/Range-Rover-4-6-HSE-Automatic-4x4-leather-18-Alloys-Mot-/302117012607?hash=item465793c47f:g:woMAAOSw44BYDjU~
Thanks Shep. Unfortunately it's a GEMS. I'm going for a Bosch.
Tidy car though, and with a bit of tweaking would make a good sub £1500 RR
Now this one has possibilities.
Would have to do head(s) and fit an lpg system, but that mileage makes it a good reseller
http://www.ebay.co.uk/itm/232136716512?
These people, however, must have a sense of humour
http://cars.trovit.co.uk/listing/2001-land-rover-range-rover.H16q1b1_iO1C
You want to know what the scary bit is of the Holland & Holland... I clicked on 'View car' and it takes you to the dealers website, where is shows that not only was the price on the dealer site £6K less at £22500, but also that it was actually sold...
http://www.ebay.co.uk/itm/Range-Rover-P38-Autobiography-4-6-V8/142172884430?
Not 100% sure on the colour, but it isn't gaudy like the purple Autobiography which is out there somewhere... It is GEMS though... but currently at £2.20...
How about this for a colour then?
http://www.ebay.co.uk/itm/2000-LAND-ROVER-RANGEROVER-VOGUE-AUTO-BLUE-/122215219119?
I'm pretty sure that's not a factory colour!
I predict that has an oil leak!! Reading the MOT history, it has been flagged as an advisory twice for an oil leak over three years.
I think an oil leak is the least of its problems Shep. I can't imagine much of a market for a baby blue P38 with clashing interior :)
